ASA Direct Authentication - HTTPS
malikyounas
I have followed the guide on the link below to configure direct authentication on ASA. HTTP part of it works fine but HTTPS doesn't.
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113363-asa-cut-through-config-00.html
As per guide the configuration quite simple to achieve and works OK for HTTP. However, as soon as I replace HTTP with HTTPs, the web page shows a certificate error which I ignore but doesn't load anything afterwards and just keeps waiting. Any idea how to get it working?
interface Ethernet0
 nameif inside
 security-level 100
 ip address 20.20.20.2 255.255.255.252
interface Ethernet1
 nameif outside
 security-level 0
 ip address 10.10.10.55 255.255.255.0
access-list inside extended permit ip any any
access-list outside extended permit ip any any
access-list authmatch extended permit tcp any host 10.10.10.55 eq 5555
access-group inside in interface inside
access-group outside in interface outside
user-identity default-domain LOCAL
aaa authentication match authmatch outside LOCAL
aaa authentication listener http outside port 5555
http server enable
http 10.10.10.0 255.255.255.0 outside
flos.jiri
Try this add:
"aaa authentication listener https outside port 5555"
