ASA logging issue
phuoctrung
Hi all
I can not view any log on ASA version 8.4.7 via ASDM, console, ssh...ASA 5520 is running multicontext mode
anyone have the same issue.
logging enable
logging timestamp
logging buffer-size 81920
logging asdm-buffer-size 512
logging console notifications
logging monitor informational
logging buffered informational
logging trap notifications
logging history warnings
logging asdm informational
logging host outside xxxx
logging permit-hostdown
logging message 113008 level notifications
logging message 113004 level notifications
logging message 611101 level notifications
logging message 605005 level notifications
7 Replies 7
Julio Carvajal
Did this work on a previous version
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
In mutiple context mode and ASA version 8.4.2, I can view message log via ASDM, ssh, console...but ASA version 8.4.7 is not. I wonder, Is this a bug?
Hmm,
If this was working with the exact same configuration then it seems like a bug.
Have you tried to look for the logs on all of the contexts?
Cheers,
Julio Carvajal
Jatin Katyal
The below listed INTERNAL defect is matching most of the symptoms you are describing here.
CSCuj16320    ASA 8.4.7 Multi Context TFW not generating any syslog data
Symptom:
ASA running 8.4.7 may not produce Syslog data at all.
Conditions:
ASA running 8.4.7
Has been observed on Multi context Transparent FW mode.
Workaround:
none
Further Problem Description:
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
Hi.
Firewall is ASA version 8.4.7 and Context mode: Multiple and Firewall mode: Routed
so yes the defect specically talking about ASA version 8.4.7 Multiple context, transparent mode and you're runnning it in routed mode. Looking at your problem description, it seems the problem is with transparent and routed both modes because with ASA 8.4.2 it works fine irrespective of firewall mode.
~BR
Jatin Katyal
~Jatin
I would also suggest you to open TAC and let Cisco know about this issue.
~BR
Jatin Katyal
~Jatin
