ASP-DROP Packet Capture
Mike Keenan
I ran the following asp-drop packet capture on my ASA 5520 Firewall:
capture asp type asp-drop acl-drop headers-only circular-buffer
I then performed the following show command. I replaced the real IP addresses with different ones so as not to reveal my internal IP addressing scheme:
show capture asp | i 172.18.2
I then got the following returns. I replaced the real IP addresses with different ones so as not to reveal my internal IP addressing scheme:
4: 21:40:47.504459 172.18.5.5.52152 > 172.18.2.65.161:  udp 79
9: 21:40:58.174459 172.18.5.5.52152 > 172.18.2.65.161:  udp 79
14: 21:41:08.314879 172.18.5.17.52152 > 172.18.2.65.161:  udp 79
Why does the destination IP address that ends with .161 (assuming that it is a destination port) also show :udp 79 (also assuming that it is a destination port?
What is the port that it is communicating to? Is it 161 or udp 79?
The destination ip is 172.18.2.65 and the destination port is 161, the udp 79 is the udp payload lenght. Please check out this link.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/command/reference/cmd_ref/s2.html#wp1391007
Aref
Aref
