Difference between failover links
mahesh18
Level 6
Level 6
Hi Everyone,
Need to understand the differences between these two
dedicated failover link and Stateful Failover link.
Mahesh
4 Accepted Solutions
Julio Carvajal
Hello Mahesh,
The stateful failover link is used to replicate all the connections that are going through the active ASA.
The failover link is used to replicate the configuration and the following info:
*The unit state (active or standby).
Power status (cable-based failover only—available only on the PIX 500 series security appliance).
Hello messages (keep-alives).
Network link status.
MAC address exchange.
That is why we recommend to use a dedicated interface different than the managment ( because of the capacity of this one)
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
What do you mean by type of failure?
Did you mean type of failover connection can be done on that crossover link?
If that was the question you can use both ( failover link and failover stateful link)
Here at cisco we recommend to use a switch between the 2 units for troubleshooting purposes ( so if one of them go down you inmediatly know where is the issue.
Julio Carvajal
To check if you are running active/active or active/standby?
If you do a show failover state:
On active/active
              State          Last Failure Reason      Date/Time
This host  -   Primary
    Group 1    Active         None
    Group 2    Standby Ready  None
Other host -   Secondary
    Group 1    Standby Ready  None
    Group 2    Active         None
====Configuration State===
        Sync Done
====Communication State===
        Mac set
On active/standby
pix#show failover state
====My State===
Primary | Active |
====Other State===
Secondary | Standby |
        Sync Done
        Mac set
Julio Carvajal
Yes, mahesh,
That is correct
Julio Carvajal
9 Replies 9
Julio Carvajal
Hello Mahesh,
Julio
Julio Carvajal
Hi Julio,
If two ASA  have crossover connection between them which type of failure is this?
Julio Carvajal
hi julio,
Is there any command  that can tell us what type of failover is running on ASA?
Or is there some config in sh run that we can check?
Mahesh
On active/active
This host  -   Primary
    Group 1    Active         None
    Group 2    Active         None
        Sync Done
        Mac set
On active/standby
====My State===
Primary | Active |
====Other State===
        Sync Done
        Mac set
Julio Carvajal
Hi Julio,
So this means we can say that stateful failover link both ASA  are in active active state?
Mahesh
Yes, mahesh,
That is correct
Julio Carvajal
Many thanks again Julio
Best regards
Mahesh
no ,
It has no relationship by active/active and active/standby .
Stateless (Regular) Failover:  When a failover occurs, all active connections are dropped. Clients need to reestablish connections when the new active unit takes over
Stateful Failover : When Stateful Failover is enabled, the active unit continually passes per-connection state information to the standby unit. After a failover occurs, the same connection information is available at the new activeunit. Supported end-user applications are not required to reconnect to keep the same communication session.
Regards ,
