11-05-2008 02:18 AM - edited 03-11-2019 07:08 AM
Normally on routers/switches, Control C takes the user out of the console display such as sh running-config. Would you know how to set the same on ASA because I have to scroll through all lines to get back the prompt.
Solved! Go to Solution.
11-05-2008 02:40 AM
use the key "q".
11-05-2008 02:40 AM
use the key "q".
