04-16-2014 05:41 AM - edited 03-11-2019 09:05 PM
I don't see any traffic information for one of my interfaces:
interface GigabitEthernet1/2
description outside
media-type sfp
nameif outside
security-level 0
ip address 152.88.1.15 255.255.255.0 standby 152.88.1.115
ipv6 address 2001:620:d::2/64 standby 2001:620:d::1002
ipv6 address 2001:620:d::2002/64
ipv6 enable
I see traffic for interface outside (show traffic)
outside:
received (in 85380.530 secs):
492990483 packets 450714511022 bytes
5019 pkts/sec 5278035 bytes/sec
transmitted (in 85380.530 secs):
332691163 packets 171970343848 bytes
3041 pkts/sec 2014012 bytes/sec
1 minute input rate 12191 pkts/sec, 9922028 bytes/sec
1 minute output rate 8888 pkts/sec, 5030000 bytes/sec
1 minute drop rate, 235 pkts/sec
5 minute input rate 12896 pkts/sec, 10971266 bytes/sec
5 minute output rate 9173 pkts/sec, 4737423 bytes/sec
5 minute drop rate, 229 pkts/sec
but not for interface GigabitEthernet1/2
GigabitEthernet1/2:
received (in 85408.020 secs):
0 packets 0 bytes
0 pkts/sec 0 bytes/sec
transmitted (in 85408.020 secs):
0 packets 0 bytes
1 minute input rate 0 pkts/sec, 0 bytes/sec
1 minute output rate 0 pkts/sec, 0 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 0 pkts/sec, 0 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute drop rate, 0 pkts/sec
Show interface shows
EEFW/pri# sh interface gig 1/2 detail
Interface GigabitEthernet1/2 "outside", is up, line protocol is up
Hardware is VCS7380 rev01, BW 1000 Mbps, DLY 10 usec
(Full-duplex), Auto-Speed(1000 Mbps)
Input flow control is unsupported, output flow control is off
Media-type configured as SFP connector
CISCO-AVAGO SFP, p/n SFBR-5766PZ installed
Description: outside
MAC address 0023.044b.5276, MTU 1500
IP address 152.88.1.15, subnet mask 255.255.255.0
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
0 packets output, 0 bytes, 0 underruns
0 pause output, 0 resume output
0 late collisions, 0 deferred
0 rate limit drops
0 input reset drops, 0 output reset drops
input queue (blocks free curr/low): hardware (0/0)
output queue (blocks free curr/low): hardware (0/0)
Traffic Statistics for "outside":
495317073 packets input, 452418015308 bytes
334595690 packets output, 173250590166 bytes
22562152 packets dropped
1 minute input rate 11350 pkts/sec, 8100118 bytes/sec
1 minute output rate 9709 pkts/sec, 6527375 bytes/sec
1 minute drop rate, 236 pkts/sec
Control Point Interface States:
Interface number is 10
Interface config status is active
Interface state is active
I would like to get interface statistics over SNMP but all statistical values for this interface are zero (other values like MTU or description are ok).
Also there is no such problem with all the other interfaces.
Outside is the only physical interface, all other interfaces are virtual on a ether channel.
Version is 9.1(1)
Any idea what's wrong here?
Thanks in advance
Thomas
02-23-2015 03:06 AM
The Problem no longer exists after updating to 9.1(5)
02-28-2015 12:19 PM
Probably this was the issue:- CSCsy66494
https://tools.cisco.com/bugsearch/bug/CSCsy66494/?reffering_site=dumpcr
Thanks and Regards,
Vibhor Amrodia
