PIX 501 speed and ipv6
snoopy866
i have 20M/20M isp speed. Will pix 501 slow my network connection? On the Cisco website, it says 60Mbps, but elsewhere on the net you can here the speed is max 10Mbps.
And the second question. Is ipv6 supported?
Tnx.
Julio Carvajal
According to Cisco Performance docummentation you will be more than fine.
Now regarding IPv6 being supported. For cisco Dedicated firewall appliances the support for IPv6 started on  version  7.0.1.
Due to memory requirements I do not think ur firewall support that version hence IPv6 will not be supported.
Jcarvaja
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
