RTSP using NAT on ASA 5540
zilliontvadmin
I have a streaming server setup with a private IP behind an ASA 5540. I've given the server a static public NAT address. Using ACL I've allowed in port 554. When trying to remotely stream from the remote client to the NAT'd server, the server gets the 554 request, but seems unable to setup the UDP stream back to the client. If the client is behind the firewall, everything works fine. Any ideas?
abinjola
enable Inspect RTSP in ASA
thanks for the reply. I have actually tried it with 'inspect RTSP' on and off. Same result.
Turns out to be an issue on the streaming server. Thanks for the response.
