10-12-2010 01:31 PM - edited 03-11-2019 11:53 AM
I am trying to find out if anyone has had luck with setting up a DMZ on a ASA 5505 with a basic license. I belive it should be possible to do but have not been able to get an outside connection to work when connecting it through a linksys router acting as an access point. Any help would be appreciated.
Bryan
10-12-2010 05:18 PM
Hi Bryan,
With BASE license on ASA 5505, we can have a maximum of 3 VLANs configured but the 3rd VLAN can communicate only with one of the other 2 VLANs that you have.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/int5505.html#wp1051819
Quoting from the above link: "For example, you have one VLAN assigned to the outside for Internet access, one VLAN assigned to an inside business network, and a third VLAN assigned to your home network. The home network does not need to access the business network, so you can use the no forward interface command on the home VLAN; the business network can access the home network, but the home network cannot access the business network."
If you have already have this cleared up but are still facing issues, please post your santizied canfig here with the problems you are facing and we will have a look into it.
Thanks and Regards,
Prapanch
10-13-2010 07:36 AM
Hi Prapanch,
Thanks for the response. We have 3 VLANS setup one for inside one for outside and the one for the DMZ. We are not wanting the DMZ to acces the inside network only access outside for clients or vendors coming in that need internet access. We have set the DMZ to restict traffic to VLAN 1 which is our inside business network but cannot get access. My other question is that we have the DMZ connecting to a Linksys router acting as an access point. It is setup to DHCP and have an ip address assigned to it but when it tries to connect all we get is DNS errors. Will post ASA config file.
Bryan
ASA Version 8.3(1)
hostname ASA
domain-name default.domain.invalid
enable password encrypted
passwd encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xx.xx.xxx.131 255.255.255.192
interface Vlan12
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 192.168.30.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
speed 100
duplex full
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 12
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa831-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup DMZ
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 8.8.4.4
object network NETWORK_OBJ_192.168.10.0_24
subnet 192.168.10.0 255.255.255.0object network NETWORK_OBJ_192.168.120.0_26
subnet 192.168.120.0 255.255.255.192object network host.10
host 192.168.10.10object network host.108
host 192.168.10.108object network host.114
host 192.168.10.114object network host.133
host 192.168.10.133object network host.19
host 192.168.10.19object network host.5
host 192.168.10.5object network host.4
host 192.168.10.4object network host.6
host 192.168.10.6object network host.74
host 192.168.10.74object network host.36
host 192.168.10.36description xxxxxxxxxxx
object network 192.168.10.179
host 192.168.10.179object network FOCR
host 192.168.10.147object network xxxxxxxxxxx
host 192.168.10.19object network NETWORK_OBJ_192.168.30.0_24
subnet 192.168.30.0 255.255.255.0object-group network net192_10
object-group network DM_INLINE_NETWORK_1
network-object host 192.168.10.114
network-object host 192.168.10.133
network-object host 192.168.10.19
network-object host 192.168.10.36
network-object host 192.168.10.4
network-object host 192.168.10.6
network-object host 192.168.10.74
object-group service rdp tcp
port-object eq 3389
object-group icmp-type DM_INLINE_ICMP_1
icmp-object echo-reply
icmp-object time-exceeded
object-group service FTP tcp
port-object eq ftp
port-object eq ftp-data
object-group service DM_INLINE_TCP_1 tcp
port-object eq ftp
object-group service Adobe tcp
description Adobe Pro Connect
port-object eq 1935
object-group service Gmail_SMTP tcp
port-object eq 465
object-group service FTP_to_IDS tcp
port-object eq 1180
port-object eq 1181
port-object range 1200 1299
object-group service Gmail_imap tcp
port-object eq 993
access-list xxxxxxxxxx_splitTunnelAcl standard permit 192.168.10.0 255.255.255.0
access-list outside_access_in remark xxxxxxxxxxx
access-list outside_access_in extended permit tcp any host 192.168.10.5 object-group DM_INLINE_TCP_1 log errors
access-list outside_access_in remark RDP for desktops and terminal servers
access-list outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_1 eq 3389
access-list outside_access_in extended permit icmp any any object-group DM_INLINE_ICMP_1
access-list DMZ_access_out extended permit ip 192.168.30.0 255.255.255.0 xx.xx.xxx.128 255.255.255.192
pager lines 24
logging enable
logging buffer-size 40960
logging asdm-buffer-size 512
logging asdm warnings
logging from-address Firewall@xxxxxxxxxx.com
logging recipient-address xxxxxxxxxxxxxxxxxxxx.com level errors
logging flash-maximum-allocation 102400
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
ip local pool ipsec_pool 192.168.120.1-192.168.120.50 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.10.0_24 NETWORK_OBJ_192.168.10.0_24 destination static NETWORK_OBJ_192.168.120.0_26 NETWORK_OBJ_192.168.120.0_26
nat (inside,outside) source dynamic any interface
nat (outside,DMZ) source dynamic NETWORK_OBJ_192.168.30.0_24 interface destination static interface any
nat (any,any) static xx.xx.xxx.158 dns
nat (any,any) static xx.xx.xxx.152 dns
nat (any,any) static xx.xx.xxx.153 dns
nat (any,any) static xx.xx.xxx.156 dns
nat (any,any) static xx.xx.xxx.159
nat (any,any) static xx.xx.xxx.150 dns
nat (any,any) static xx.xx.xxx.160 dns
access-group outside_access_in in interface outside
access-group DMZ_access_out out interface DMZ
route outside 0.0.0.0 0.0.0.0 xx.xx.xxx.129 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server WINad protocol ldap
aaa-server WINad (inside) host 192.168.10.174
ldap-base-dn DC=mxxxxxxxxxxxx,DC=com
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password xxxxxxx
ldap-login-dn CN=xxxxxxxxxxxx,CN=users,DC=xxxxxxxxxxxx,DC=com
server-type microsoft
http server enable
http 192.168.10.0 255.255.255.0 inside
http 192.168.120.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.10.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy xxxxxxxxxxxxx internal
group-policy xxxxxxxxxxxxx attributes
wins-server value 192.168.10.176
dns-server value 192.168.10.176 192.168.10.174
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecifiedsplit-tunnel-network-list value xxxxxxxxxxx_splitTunnelAcl
default-domain value xxxxxxxxxxx.com
split-dns value xxxxxxxxxxxxxxx.com
username xxxxx password xxxxxxxxxxxxxx encrypted privilege 0
username xxxxx attributes
vpn-group-policy xxxxxxxxxxxxx
tunnel-group xxxxxxxxxxxxx type remote-access
tunnel-group xxxxxxxxxxxxx general-attributes
address-pool ipsec_pool
authentication-server-group WINad
default-group-policy xxxxxxxGroup
tunnel-group xxxxxxxxxxxx ipsec-attributes
pre-shared-key xxxxxxx
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
policy-map global_policy
class inspection_default
inspect dns preset_dns_map inspect h323 h225 inspect h323 ras inspect netbios inspect rsh inspect rtsp inspect skinny
inspect esmtp inspect sqlnet inspect sunrpc inspect tftp inspect sip
inspect xdmcp inspect ip-options inspect ftp strict !
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService destination address email callhome@cisco.com destination transport-method http subscribe-to-alert-group diagnostic subscribe-to-alert-group environment subscribe-to-alert-group inventory periodic monthly subscribe-to-alert-group configuration periodic monthly subscribe-to-alert-group telemetry periodic dailyCryptochecksum:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
: end
10-13-2010 07:57 AM
When you say you "cannot get access" what and how are you trying to access from where? Also, what is the DNS error that you are getting? If possible, please draw a corresponding line topology if possible.
Thanks and Regards,
Prapanch
10-13-2010 09:23 AM
Thanks again for the quick response. Okay the DMZ is connecting into a Linsys router serving as an access point. This way vendors can come in and hookup their laptops through wireless connect. There is not a specific error or code it just cannot resolve a DNS host. The router is setup to use google DNS servers @ 8.8.8.8. I will include a topology diagram. Maybe this will explaing better.
