Can't start guestshell on Cisco 4331 on 16.9.6
Difan Zhao
Level 5
Level 5
I am new to the development and coding in Cisco. I am studying guestshell. I am following this post for instructions.
https://community.cisco.com/t5/developer-general-blogs/introducing-python-and-guest-shell-on-ios-xe-16-5/ba-p/3661394
When I do "guestshell enable", I got this error: % Error: No interface configuration for guestshell
Then I found a solution on google to specify the management interface for the guestshell.
app-hosting appid guestshell
 vnic management guest-interface 0
end
First of all, when I specify the interface, I got this error. What does it mean, and is there now a replacement command for this?
Dec 18 15:52:56.159 CST: %PARSER-5-HIDDEN: Warning!!! ' vnic management guest-interface 0' is a hidden command. Use of this command is not recommended/supported and will be removed in future.
Now I am able to start the powershell and I can get in the Bash. However, in the base, I don't have any internet connectivity.
#guestshell run bash
$ ping 4.2.2.1
PING 4.2.2.1 (4.2.2.1) 56(84) bytes of data.
From 192.168.30.1 icmp_seq=1 Destination Net Unreachable
My router has three interfaces Gi0/0/0-2. Only traffic sourced from G0/0/1 can reach the Internet. The Mgmt G0 interface is not connected. When I tried to specify other numbers for the interface, I got this error when I enable guestshell
% Error: The guest-interface number [eth(1)] is higher than the expected number of [eth(0)]
Please let me know how to get the powershell running properly in this setup. Thanks!
omz
They are indeed very helpful! Thanks omz. I am able follow through the steps but I see a small difference in the running-config. The config I put in was "vnic gateway1 ..." but in the running config, it becomes gateway0. In the config, gateway1 is the lowest I can choose. I would assume that vnic gateway1 is app-vnic gateway0, correct?
app-vnic gateway0 virtualportgroup 0 guest-interface 0
guest-ipaddress 192.168.1.2 netmask 255.255.255.0
name-server0 8.8.8.8
I would assume the same ...
