EEM script - append custom text to file in flash
Brett Verney
Hi there,
Is there a way to append custom text to a file in flash using an EEM script?
For example, if I had a script that did the following:
action 001 cli command "show version" | append flash:output.txt
action 002 cli command "show logging" | append flash:output.txt
Could I insert a headers such as:
---------- SHOW VERSION ----------
---------- SHOW LOGGING ----------
in to the 'output.txt' between each of the command results?
I'd expect it to look something like this:
action 001 <some_command> ---------- SHOW VERSION ---------- | append flash:output.txt
action 002 cli command "show version" | append flash:output.txt
action 003 <some_command> ---------- SHOW LOGGING ---------- | append flash:output.txt
action 004 cli command "show logging" | append flash:output.txt
Brett
balaji.bandi
You can try
action 001 puts  "---------- SHOW VERSION ----------" | append flash:output.txt
BB
