Exists FMC API exposed via FMC API for HA Device DHCP Relay Config?
tham89
Marcel Zehnder
I don't have access to FMC at the moment, however the FTD API seems to have corresponding endpoints:
https://developer.cisco.com/docs/ftd-api-reference/latest/
Interesting then in your opinion if no such endpoint exists in the FMC OAS then this simply is unpossible for FMC-managed those boxes?
Well, I just don't know - I don't really know the FMC API and because I don't have access to a FMC REST Explorer I can't check the corresponding endpoints - I would expect it should be possible via FMC API, but without an API doc I'm not sure. Hope the FMC sandbox is working soon again, then I can check.
Curious if there is an answer for the FMC API DHCP Relay/Server config.  I can configure everything else I need except this via the API.
