Ingesting data from Cisco APIC(ACI) 3.2(2i)
We are building data hub and trying to extract below information from APIC 3.2 REST API's
IPAddress
macAddress
portName
portID
vlanID
I could not find any class or mo URI from APIC object store browser. Could you please help me out to identify the right API's to get the above data from ACI?
Many thanks in advance.
Ramesh
omz
Have you tried API inspector? Whatever you can see on the APIC dashboard .. you will be able to the corresponding API call in the API inspector.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/api/rest/b_APIC_RESTful_API_User_Guide/using_tools_for_api_development_and_testing.html#d6474e26a1635
please don't forget to rate helpful posts and accept solution so others can benefit.
