IOS-XE sandbox devices are not access
rbf
We can no longer push configuration via Ansible to the following devices:
ios-xe-mgmt-latest.cisco.com
It seems to be a privilege issue:   msg": "operation requires privilege escalation"}
Could you please have a look at it?
Thank you.
@rbf i made the ENG team aware, the always-on sandbox reset themselves via automation after a period of time, due to these being accessible from any user. Changes can get made which prevents other uses from accessing the sandboxes at some times.
In the meantime try this other XE always-on sandbox --> https://devnetsandbox.cisco.com/RM/Diagram/Index/27d9747a-db48-4565-8d44-df318fce37ad?diagramType=Topology
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
