ISE Posture Client Provisioning Portal(Captive Portal)Issue on macOS
sithum
I configured the ISE Posture agent to check for the installation status of five applications on macOS and Windows. However, on macOS devices, the Client Provisioning Portal appears when logging into Wi-Fi, but when opened, it displays the error: 'This browser is not supported. Close this window, switch to a supported web browser such as Safari, Chrome, or Firefox, and try again.'
I changed the default browser to Safari, Chrome, and Firefox, but the default browser does not launch when logging into Wi-Fi. The same error message keeps appearing.
Windows devices work without any issues. Has anyone else encountered this problem.
Version:3.3.0.430
Patch Information: 3,4
Sithum Dinushan
TanyaYuan2296
I had a TAC open on this before, in your WLC, enable "Captive Bypass Portal" would work, but note that this is a "global" setting.
bryan-cruz
I have the same problem, what did you do to solve this issues?
