6.1 What is the Domain Name when using LDAP
We are currently installing Tidal 6.1, we are going to integrate Oracle Directory Server for LDAP (not AD).
Qustion is, what is the domain name we have to provide when we install?
Master and CM both on Linux.
Thanks!
Maximilian Gallagher
I don't think that ODS is supported with TES, but I've seen it work. If it's another version of LDAP like AD is, then you'd provide the LDAP domain. "AD" is just a specific configuration for LDAP.
Do you know any document which shows LDAP compatibility?
I havent seen on Intsallation Guide.
Problem is, when I install, linux servers are on different network (domain) but LDAP contains different domain details. Wondering how Tidal check the domain details when authenticating.
When we give LDAP domain details, it gives following error.
WARN:  javax.security.auth.login.LoginException: [LDAP: error code 49 - Invalid Credentials]
Anyone know how to increase log level to debug?
Thanks!
