Adapter Compatibility w/ MSSQL 2012 on TES 5.3.1
aebrigham
Hi There,
I was hoping if anyone has had success connecting their TES 5.3.1 master using the MSSql Adapter to MSSQL 2012.  The DB Version must be specified when creating a new Connection Definition.  Because this is required I receive the following error in the MSSqlService*.log file.
03/06 15:25:28:842[21:MD-12]: (mem=11367216/16711680) com.tidalsoft.service.logic.ServiceException: QA_SSSQL2_AGENT verifyVersion: version mismatch: connection version = SQL Server 2008, database version = 11
I am not surprised by this because I have specified 2008 when actually I am connecting to a 2012 instance.
Has anyone had success doing this?  You help is greatly appreciated.
Andrew
smshawgames13
Cisco logged this as a bug and a pending fix to be released.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCug95611
Bug: CSCug95611
Request to support SQL Server 2012 with the 5.3.1 MSSQL adapter.
Symptom:
Conditions:
CUrrently only support SQL Server 2005 and 2008
Workaround:
none
Does anyone know if there has been any progress on this bug? I can't see it due to "insufficient access".
Also has anyone had success with running SQL Server 2012 jobs on Tidal 5.3, maybe by using a bridge program?
Amir
This bug is fixed and released per online bug:
https://tools.cisco.com/bugsearch/bug/CSCug95611
