12-12-2014 01:59 PM
I'm doing a fresh installation of CIAC 4.1, installed CPSC and also finished importing/deploying portal pages and done with Rex Adapter installation.
While deploying service package 'SC_Services_4-1.xml', it's just not finishing the deployment in spite of waiting for hours together. It seems to be quite a huge package at 56 MB, and we did have had difficulty deploying even 2 MB xml files in the previous 10.0 version.
We increased the heap size to see if that helps to 1 GB but it didn't help.
Appreciate your input on how to address this problem. Without resolving this, we cannot proceed with CIAC installation/configuration. Thank you
12-16-2014 09:12 AM
It is best to file a TAC SR for such an issue. Also, I suggest that you post this to the IAC forum.
12-16-2014 09:25 PM
Thank you Song for your response. I just posted it in the IAC forum, just thought the issue is with the Catalog Deployer and hence posted here to see if anyone has faced the problem.
