CPO integration with AWS
vigneswaram
Hi Team,
Can anyone provide the details how to communicate with AWS and Azure (create vms, create networks ...) using CPO? Do we need to import any TAP files,pls suggest and also provide documents related to this.
My current cpo version is: 3.0.0.1090
Vignesh.
Shaun Roberts
If you have later versions of CIAC then there is some integration with AWS in there I believe. Either way you can integrate via Web Service calls with those applications. (Using Web Service Adapter and it's activities). I personally do not have any examples but I would look at the online doc for those web services and write them into CPO if CIAC does not offer you what you want.
If you look at my blogs on web services and such you can see some examples of general web service writing and calls.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
