If you have later versions of CIAC then there is some integration with AWS in there I believe. Either way you can integrate via Web Service calls with those applications. (Using Web Service Adapter and it's activities). I personally do not have any examples but I would look at the online doc for those web services and write them into CPO if CIAC does not offer you what you want.
If you look at my blogs on web services and such you can see some examples of general web service writing and calls.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
