DataStage - Does anyone have it configured?
BTS OPERATIONS
Hi All - I know Cisco chose to eliminate use of Connectors in 6.x  And they decided not to create a DataStage adapter.
Does anyone have a method in place for Tidal and DataStage to talk directly?  I'd like to discuss it with you if you do.
Thank you,
Michelle Morris
HI,
We created a shellscript  that invokes datastage jobs from unix box using dsjob command. We have been successfully able to run our daily etl schedules using this method.
Kranthi
