11-17-2011 06:02 PM
During deployment we got an error message 'Element SERVICEFORMS is undefined in CI'. Can anyone explain what that means and what we did wrong?
Thanks.
11-17-2011 06:03 PM
Hi Christine,
I presume when you say "During deployment" you are referring to CatalogDeployer - yes? I am not familiar with that particular error. Please open a case with Customer Care, since this might be a defect.
11-17-2011 06:03 PM
Hi Ed
I think the error has somthing to do with the service name. I guess when my colleague copied & pasted.the service name, she also copied some hidden codes. I've deleted and reentered the service name manually. The deployment is due on Monday, so let's see if it helps. Will let you know.
11-17-2011 06:03 PM
I have this same error. Did your approach correct the problem? Thanx!
11-17-2011 06:03 PM
Yes, the approach seemed to work. We had no problem deploying after editing the service name. The problem must be due to some hidden code when we copied & pasted the service name from the template.
11-17-2011 06:03 PM
somehow you have broken the XML format, probably copy copying and pasting, which resulted in bad formatted xml message, and CD could not locate the serviceform tag ...
