Error when updating DATETIME ServiceItem fields.
sukstansky
Community Member
Hi. I get 422 error when trying to update DATETIME service item fields. Here is what I do: get timestamp as a string, use parse date activity to covert it to DATETIME and use the result as an update value in update service item activity. Looks pretty straightforward, but I get "Unprocessible entry" error every time. String parsing is successful, other fields in the same SI can be updated fine. Any suggestions? Thank you in advance.
Shaun Roberts
I'm not sure if the DATETIME internal time for CPO is the same as CPSC. Have you tried just passing in a string without converting?
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
