Errors while deleting users
ramillar10
Community Member
                   I am deleting obsolete users from Tidal but getting error ranging from user is owner of calendars, user is owner of jobs, user in use by an agent.  I have checked and do not see any of the users I am trying to delete as owners of calendars, jobs, or in use by an agent.  Has anyone experienced this issue?  - Thank you.
Marc Clasby
Level 6
Level 6
Users likely own objects (calendars, jobs, variables, etc.) therefore so you can't delete that user
you can impersonate them prior to deleting then see if they own any objects which usually works well
If you still struggle, reply ... I probably have a SQL script or can put one together for you (if your tidal back end is SQL)
Marc
