Externally Defined error in Tidal Job execution
Mahalengam
I have executed a Tidal Job in the Test environment, the job runs successfully, but i the status says Externally Defined and the job seems failed.
The same job runs successfully in the Dev environment.
Attached the screen shots.
Kindly let me know, to fix this issue.
Mahalengam
This issue got resolved. I need to add a script in the SP: PRINT 'Process Successful: ETL_Process_ID: ' Basically the Tidal Job is looking for for the text: Processful as the result of the execution
