Fatal Error Unable to delete connection
mlr_1126_
Error messsage when trying to delete connection node.
TES_019003: Cannot delete selected record. Remove node_id{36} in Dependency reference first.
I am unable to find this depenedency reference.
Please help.
You're going to have to do the following:
1.  filter for all your jobs and job groups for those defined on this Agent.  They must be changed to a different node/Agent before you can delete the agent
2.  any file dependencies you have programmed in your environment which use this node/Agent must be also reprogrammed/removed before you can delete the agent.
At minimum, these must be done prior to being able to delete a node/Agent
-Dwayne
Thanks Dwayne for your suggestion.
I have filtered my jobs & job groups included and 0 Records are found.
I did however finally find the file dependencies which I removed and was able to Successfully delete node/agent.
Thank you so much for your reply.
Michelle
