SAP Web Dispatcher monitoring
dcook3101
I've gone through the documentation but do not see how to configure SAP Web Dispatcher monitoring in CPO 3.0.  Is this possible?  If so is there any documentation showing how to do it?
Many thanks,
David
Shaun Roberts
Hi David,
 Are you talking about monitoring the java stack side? What do you normally do to monitor SAP Web Dispatcher? Or is there some T-CODE you use to monitor it?
I see a process to monitor Dispatcher logs in the J2EE Infrastructure category. Which is for the Java Stack side of monitoring. If you want to implement that you need to create your SAP targets and then define the SAP Java sub targets that go in them. You will then need to go into the target and configure the target property for Dispatcher logs. Let me know if that helps.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
