Hidden Input Type cannot be updated by rule?
lim.park01
So is it correct that if a field's Input Type is set to hidden on the Form's Display Properties, that the field value cannot be set by a rule?
I thought if the field is hidden, it is still sent and present on the browser if the user has Access Control rights.
Is there a difference in terms of ability to set value by rule if field is hidden from Form's display properties vs. hidden by another rule after making it visible from Form's display properties?
Thanks.
derevan
Level 4
Level 4
Under display properties, when you make a dictionary field "hidden",  the default is to also mark it as "editable on server side only". This  will prevent a rule from updating the value. Be sure to uncheck this  option and your rule should work fine. Or execute your rule on submit/server side.
"Editable on server-side only" was not shown as checked, but it still was not able to update the field via rule on form load.
This was after upgrade to 10.0, for something that was working before, so it might be something caused by the upgrade. Since "Editble on server-side only" did not exist in our old version, is it possible that during the upgrade it enabled that by default for hidden fields on the back-end somehow, even though in the UI it was still shown as unchecked?
After changing the Input Type to something else, and then back to hidden, and unchecking it again (since it checked by default when changing back to hidden), now it is working ok again as hidden field, so it appears that setting needs to be "reset" somehow.
Thanks.
Hmm... I thought it was working if I "refresh" the settings as I outlined, but it does not actually.
It seems if the field is set with display type of 'hidden', conditional rules cannot update the field value, even with the "editable on server side only" check mark cleared. If the display type is set to 'read-only' for example, and then hidden by a rule, then another conditional rule can update the field's value, so the rule itself appears ok as well as access control.
