How to integrate Cisco Process Orchestrator with Cisco Prime Service Catalog
muthukumar.d
I want to integrate Cisco Prime Service Catalog with Cisco Process Orchestrator using service link.
How to integrate it. Is there any docs for CPO & CPSC integration.
Shaun Roberts
This is how the CIAC solution is constructed. At a high level...
1) Order in CPSC, an action creates the nsXML for output
2) nsXML goes through a transformation to CPO XML
3) CPO XML is passed into CPO's Northbound Web Services which starts a process
4) process does work and can make calls back to CPSC through the adapter or web service calls
Do you have both products but do not have CIAC content?
At a high level they integrate through web services. There is no real doc/how-to since (as I started above) it is how CIAC is constructed so it is sold as a solution.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Shaun Roberts
--Shaun Roberts
shaurobe@cisco.com
