How to iterate a CSV String using Index
shabalas
Hi Team
I have a CSV String. I need to iterate through the string and use Index to address to a particular element in String. I have used Split String activity but it just runs in the For Loop to get the values.
I need to have the provision to take 'i' th element using an index which I can run in the loop.
In other words, could I have the provision of array definition in CPO and refer  any 'i' th position in the array using an index
2 Accepted Solutions
Hi, Shankar!
Using the XSL Transform activity in the product with the XSLT below you should be able to convert your comma-separated string into a XML that can be read into a table with 2 columns (Idx and Value, where Idx is the numeric number of the row).
The XML produced by the XSL Transform activity could be read into a table using Read Table from XML activity.
The XSL is expecting that you will put your string into tag.
xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
Svetlana
I'd go with regex for a string like that.
Prepend a comma to your string by hardcoding it so that your input looks like
,[Process.Variables.Local.CSVString]
Then use the following regex:
(?<=(.*?\,){[Process.Variables.Local.Nth]})\w*
The input of
,val1,val2,val3
to regex
(?<=(.*?\,){2})\w*
will return "val2" in "First Match" of the regex activity output properties.
7 Replies 7
Shaun Roberts
I suppose you could write a function to take a string and convert it into a 2 column array where one column is the character (or string) and one column is the index. Then you can do select statements to pull the exact index.
You cannot call a string (or even array) like you would in native programming language since the for-each loop is not a true for loop, it's made for tables.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
This can't be done in a single step, but depending on what you have, it can probably be done in more than one step.
Is it a multi-line, multi-value string?  Most CSVs are of the form:
Value1,Value2,Value3,...
Value4,Value5,Value6,...
Are you trying to get to "Value5" above?
You might be able to use Regex, or the Read Table From Text followed by a Select From Table, or an XSL Transform to achieve what you want.
What does your string look like?
My String  is Single line and looks like:
val1,val2,val3
Hi, Shankar!
Svetlana
Once you have the data in a table like this you can either iterate over all values in a while loop.
Or you can use Select from Table activity to select a row with a specific Idx value.
The input of
,val1,val2,val3
to regex
(?<=(.*?\,){2})\w*
Mike's regular expression support is much lighter implementation if all you want to retrieve is an nth entry in the list.
