Is it possible to pass variables from Tidal to the Peoplesoft run controls?
Jay Kish
Does anyoen know
  • •1) Is it possible to pass variables from Tidal to the Peoplesoft run control page such as current date?
An example would be updating run control parameters for a PSQUERY.
  • •a) From date
  • •b) To date
  • •c) Business units
Jay
Lumi Mihalcea
Edit the job - go to Run Controls Parameters tab - select the param you want in the Override column then click on the Variables button on the bottom and select the variable you want
