Job group not loaded in Tidal
Viji
We have a job group with calendar daily not loaded one particular day last week,completed successfullyon previous days and after that;all other job groups were loaded except this one group I couldnt find any logs about someone removing that job group;Where can I find the information or logs to find why this job was not loaded ... Thanks
Derrick Au
Level 4
Level 4
Hi Viji,
From the webUI select Logs and filter on either the Current Day or Date Range
and Message Text should include the following (not case sensitive): your request to remove job
The same result can be found via SQL query:
select * from msglog where msglog_crtdt >= '1/2/2019 13:00' and msglog_crtdt < '1/2/2019 13:16'
and msglog_text like '%your request to remove job%'
order by msglog_crtdt
Best Regards,
Derrick
