Linux Tidal Agent not Connecting
jimmboyc70
I installed the Tidal agent for UNIX v3.0.2.06 on a Linux (Red Hat 4.1.2-48). the install went well I thought.  when trying to start the Tidal service it fails on the "Opening Connection."
I opened a telnet session to the Tidal Master on port 5912 so I know that the Linux box can talk to the Tidal Master.
So can someone tell me why the connection is failing?
Below are the Linux flavor and the error message from the Tidal service start failure:
# cat /proc/version
Linux version 2.6.18-194.el5 (mockbuild@ca-build10.us.oracle.com) (gcc version 4.1.2 20080704 (Red Hat 4.1.2-48)) #1 SMP Mon Mar 29 22:10:29 EDT 2010
# /sbin/service tidal start
Starting TES agent: ------------------------------------------------
*** Agent Instance : tidal_agent
TIDAL Agent for UNIX
Starting agent tidal_agent on port 5912
Opening Connection.............................Failed
jimmboyc70
I was looking in the log file for the Tidal agent instance and it looks like it
is a NoClassDefFoundError and a ClassNotFoundException issue. Here is the
complete log.
Exception in thread "Thread-1" java.lang.NoClassDefFoundError: v
at java.lang.Class.initializeClass(libgcj.so.7rh)
at k.(Unknown Source)
at JAgent.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException:
sun.security.action.GetPropertyAction not found in
gnu.gcj.runtime.SystemClassLoader{urls=[file:/opt/TIDAL/Agent/lib/TAgent.jar,fil\
e:/opt/TIDAL/Agent/lib/agutil.jar],
parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}
at java.net.URLClassLoader.findClass(libgcj.so.7rh)
at java.lang.ClassLoader.loadClass(libgcj.so.7rh)
at java.lang.Class.forName(libgcj.so.7rh)
Any ideas?
What version of java is the agent picking up?
I'd suggest getting hold of java 1.6.0_xx from Oracle and run with that. xx is currently in the high 30s.
Cheers
