04-28-2013 11:25 PM
Hey Guys
I keep hitting the maximum amount of characters limit of 512 for service item fields on the forms in IAC
Has anyone hit this issue and found a workaround?
It is making our forms quite limiting with what we are trying to do.
Thanks in advance
Matt
Solved! Go to Solution.
04-30-2013 10:10 PM
Matt, sounds right. The largest supported service item attribute type is String (512). I am curious to know your use case, though. Not all form fields need to be service item backed.
04-30-2013 08:35 PM
Hey Matt,
Which field(s) in particular are you looking to enter string lengths greater than 512 characters?
04-30-2013 08:55 PM
Hi Lee
Thanks for your response,
I have tried this with Text Area, Multiple Selection and Text fields on the form.
I even receive the error attempting to write into the SI directly through IAC.
Matt
04-30-2013 10:10 PM
05-01-2013 10:30 PM
Hi Lee
This is mainly on forms that I use for microsoft exchange provisioning.
I have distribution groups that might have 30 users in them, and i am using a multiple selection field to facilitate the selection of all users, they select on username and the approx 30 usernames goes past the 512 limit.
I know you can change the nvchar limit to max in the database however i am unsure as to what effect this would have on the service item.
I have tried this many ways and is the only viable way to select users.
Also i use the text area to enter multiple line separated email addresses and am having the same issue.
Matt
