Hello guys:
Seems that show commands and configuration commands work fine with Nexus API but there is not information on how to use API to copy to bootflash:, as when you apply the command, nexus asks you the source file name and the server authentication and ip.
It does not work to use something like "copy ftp://USER@X.X.X.X/FILENAME bootflash:" because at the end, it asks you for a password, and for some reason, sending multiple commands on the same API POST does not work for this case, it works for configuring regular stuff, sending "config t ; interface e1/1 ; no shut" for example, but sending something like:
"ins_api": {
"version": "1.0",
"type": "cli_conf",
"chunk": "0",
"sid": "1",
"input": "copy ftp: bootflash: ;file.txt ;VRF_NAME ;SERVER_IP ;user ;password",
"output_format": "json"
con the same API POST does not work, the answer at the end is:
"jsonrpc": "2.0",
"error": {
"code": -32009,
"message": "Request timeout",
"data": {
"msg": "\nEnter source filename: \n"
nexus times out because never receives the sourcefile name... even when the post has it.
