Not able to create Unix/Linux Target in CPO
Prashant Raghav
While i am trying to create any Unix/Linux target in CPO i am getting the below error.
"Unable to establish a session with the Adapter Host Framework.  No response was received to our Adapter Host Connection Request Message."
I am getting this error, even i am using any existing target.
Some JRE files were missing in my JAVA folder. So, I have re-installed JRE files and setup JAVA_HOME path as well.
Any suggestions please?
7 Replies 7
Warren Ackerman
What version of PO and patch level are you using?
Also what version of JRE? This is usually related to JCE not being setup/configured properly.
We are using 3.0 with Latest Patch and jre-7u60-windows-x64
Same JREs versions are working fine in other CPO environments.
Please be specific on the patches installed. You can find this info in the help-about.
Thanks Warren.
I have copied JCE unlimited files under the \security folder–
US_export_policy and local_policy
Issue is resolved now.
Another workaround is to either reinstall patch 3 or the latest patch of PO that includes patch 3 fixes. It should redeploy the JCE files.
