Pass on Job Output with single quotes
HiWorld123
As described in the docs, Tidal can pass on job output via the command line. However, my job output can sometimes contain single and/or double quotes.
This could then e.g. lead to the following, which won't run because of unbalanced quotes
run some_script 'sample ' job output'
Is there a workaround so that quotes can get stripped from the job output before it is passed on? I tried using a variable, which seems to work, but unfortunately can only hold 255 characters.
Thanks.
0 Replies 0
