Patching CSCP 9.4.1R2 Patch 4
Alejandro Madurga Ainoza
Hi all,
I´m trying to install a CSCP 9.4.1 R2, the installation went well, but now I´m going to apply the Patch #4 and there is a part of the instructions that I found some problems.
On step 7 it refers to isee.war directory, but in my actual installation there is no isee.war directory:
The instuctions:
Step 7.    Update the Service Link (ISEE.war) files by extracting the "isee_war.zip" archive to the deployed
ISEE.war directory, overwriting existing files and keeping the directory structure intact.
The directory structure for Service Link:
Maybe some files are missing on the install.
Thanks in advance,
Alex.
lim.park01
I saw that too, and I believe this should be a documentation defect.
ISEE.war should be ServiceLink.war. Just replace all references to ISEE.war in the documentation/readme with ServiceLink.war, and you should be good. Just unzip the isee_war.zip in to the ServiceLink.war directory.
lim.park01
Thaks a lot Lim,
I patched as you said, and everything is working perfectly, I´ll open a case on support to update the documentation.
