Peoplesoft Tidal Job: Run New occurrence vs. Rerun same occurance
jeff.hamway01
Hello Everyone,
I am using Tidal 6.0.3 and scheduling a PeopleSoft Query job.  What is the difference with  ' Run New Occurrence' and 'Rerun Same Occurrence'
Do these choices also get applied to the PSQuery instance where it will re-run the PSQuery if you choose ' Run New Occurrence' in the tidal scheduler?
Thanks in advance
Jeff
This answer is not specific to PS ...
The new occurrence creates a new instance of the job that you ran. For example if your Tidal job id was 100, the new occurrnece would be 101. You will see two entries in the run history.
where as
Rerun occurrence simply reruns the same job and retains the same Tidal job id. In this example, it would be 100. itself. You will see only one instance in the job run history. The job output in TES also gets overwritten.
In both cases, the backend action generally is the same(re-run of the query). I would assume the same for PS jobs as well
where as
