Sanjeevan P
8:09am, May 11
Kunal - there are no errors in the log file you attached. You may want to confirm and upload again.
Couple things to check:
1. What is in the Mid-Tier logs?
2. Have you tried using the External XML message in a tool such as SOAPUI? That is a good way of testing the message being built by the outbound transformation.
Emir (2008.1)
10:34am, May 11
it could be a port issue, a listener issue, seems you are on a cluster and SL is not cluster aware, maybe connectivity from server XYZ to SL is failing ....logs have no errors, did you attach the worng log?
