SMTP for Cisco IAC 3.1
otavio.augusto
Hi all
Where do I change the smtp server information in a portal which is already installed and running?
/O
Otavio Augusto
meisenst
Level 4
Level 4
Locate the file
C:\jboss-as-7.1.1.Final\standalone\deployments\RequestCenter.war\WEB-INF\classes\config\newscale.properties
Change the value for
ObjectCache.email.host
From M. Dupont:
It is also critical to set the actual return email address. In 3.1 this is done in the System Setup portal page in the System Settings tab. There is a task named Set System Email Account.
