TES v6.1 Job.Insert using name or alias
bryian.ctr.tan
hello,
The following XML work fine when I use job id 166. I tested it on http://localhost:8080/api/tes-6.0/postscreen .
<?xml version="1.0" encoding="UTF-8"?>
<entry xmlns="http://purl.org/atom/ns#">
<id>12</id>
<tes:Job.insert xmlns:tes="http://www.tidalsoftware.com/client/teservlet">
<tes:id>166</tes:id>
<tes:startdate>20130614</tes:startdate>
<tes:vars>a_parm=hello from TES v6.1,b_param=1 23 4 5</tes:vars>
<tes:deps>N</tes:deps>
</tes:Job.insert>
</entry>
How do I use job name or alias? I tried both
<tes:name>TestGroup</tes:name> and <tes:alias>TestGroup</tes:alias> but getting the error "exception:java.lang.reflect.InvocationTargetException reason: description:Could not find RPC parameter [object]..."
Please advice.
Bryian Tan
Prakash Hemchand
HI Bryian,
You have to use the jobid, the name and alias are not valid in this case.
Prakash
