Tidal 6.3.3: inserting a job into the schedule via web interface works; the same via API returns an error
I have a dummy job created that I can insert into today's schedule and watch run with no issues. When I try to do the same using the sample form in the API Docs area for method JobRun.Insert, I get back a large java exception the only clear information I can derive from which is this:
Caused by exception:java.lang.reflect.InvocationTargetException reason: description:Job(s) start date is not part of compiled schedule.
The values I'm passing in the form are these, just the same as when I add the job in the web interface:
id	872280
startdate	03012019
fromtime	12:00 AM
untiltime	11:45 PM
params	-lrt
vars
deps
usejobtz	N
Any thoughts on this would be appreciated--my team sees a lot of potential in the API provided but getting it working is proving to be challenging.
Update -- It would appear that this is because the API expects the datestamp to be in the form of yyyymmdd and fromtime and untiltime fields expect a timestamp in the form of hhmm in 24h style, rather than the hh:mm AM/PM used in the gui
