Tidal Job Specific Exit Code
jmuchhala
How do I put specific exit codes instead of range. I have a special case where exit code 1,3,5 and 7 are normal behavior all others are abnormal. I am using Tidal 5.3.1. Any help would be appreciated.
Derrick Au
Level 4
Level 4
Hi jmuchhala
Exit codes cannot be specified individually, a range is generally acceptable or using Normal odd/even (in your case, odd) but I am not sure what the range of exit codes you have. Since all other behaviors are considered as abnormal, is there a persistent string that you can scan for? If so, then you can select Scan Output: Abnormal String(s)
BR,
Derrick Au
