Values not migrated with Catalog Deployer
joshua kobow
Service values for Inbound and Outbound adapter for an HPSD Work Order agent do not get deployed to target environment.
When performing a catalog deployment, a group of fields do not get deployed.  The Inbound and Outbound values in a Service Authorization for an HPSD Work Order agent do not get set.  The values in the Service are necessary for work orders to fire.  After a catalog deployment, the values have to be set manually.
Service Group Authorization
Workflow Type
Outbound and Inbound Parameters
Hi Joshua,
Please open a case with Customer Care on this one. In the meantime, though, here is some advice from our technical trainer.
This is a bit of a chicken-and-egg situation. Since the service refers to the agent, the agent needs to be deployed before the service, via Custom Deployment. However, the agent refers to fields in the service, so they don't get properly deployed.
If you try to deploy the agent again, it *might* work.
joshua kobow
It did not work to deploy the agent, then the service.  Thanks for the advise, though, Ed.  I'll submit a ticket with Customer Care.
