11-17-2011 05:39 PM
Authentication via the AuthenticationService is successful, returning a valid Session ID. Authentication via passing an AuthenticationToken in the SOAP Header fails with an error of AUTH_0005 The user name header is invalid ....
We are calling newScale web services from an external application. Making a call to the AuthenticationService using this SOAP request is successful:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:aut="http://authentication.api.newscale.com">
<soapenv:Header/>
<soapenv:Body>
<aut:authenticate>
<aut:userName>username</aut:userName>
<aut:password>password</aut:password>
</aut:authenticate>
</soapenv:Body>
</soapenv:Envelope>
The return data is:
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soap:Header>
<AuthenticationToken>
<Username>username</Username>
<SessionId>1FD9023262278342CACF63D0D6C5A8F2</SessionId>
</AuthenticationToken>
</soap:Header>
<soap:Body>
<ns1:authenticateResponse xmlns:ns1="http://authentication.api.newscale.com">
<ns1:personInfo>
<active xmlns="http://authentication.api.newscale.com">false</active>
<email xmlns="http://authentication.api.newscale.com">fakeuser@hotmail.com</email>
<employeeCode xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
<firstName xmlns="http://authentication.api.newscale.com">user</firstName>
<homeOrganizationalUnitName xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
<lastName xmlns="http://authentication.api.newscale.com">name</lastName>
<localeName xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
<login xmlns="http://authentication.api.newscale.com">username</login>
<managerEmail xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
<managerName xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
<managerPhone xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
<placeName xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
<status xmlns="http://authentication.api.newscale.com">0</status>
<timeZoneName xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
<title xsi:nil="true" xmlns="http://authentication.api.newscale.com"/>
</ns1:personInfo>
</ns1:authenticateResponse>
</soap:Body>
</soap:Envelope>
However, when we pass credentials in an AuthenticationToken when accessing any of the other services, we get an error. For example:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:req="http://requisition.api.newscale.com">
<soapenv:Header>
<req:AuthenticationToken>
<req:Username>username</req:Username>
<req:Password>password</req:Password>
</req:AuthenticationToken>
</soapenv:Header>
<soapenv:Body>
<req:getServiceDefinition>
<req:initiatorLoginName>username</req:initiatorLoginName>
<req:customerLoginName>username</req:customerLoginName>
<req:serviceName>VMSpinup</req:serviceName>
</req:getServiceDefinition>
</soapenv:Body>
</soapenv:Envelope>
Yields this error:
<soap:Body>
<soap:Fault>
<faultcode>soap:Server</faultcode>
<faultstring>The user name header is invalid. It is either not present or empty!. Please send a valid header.</faultstring>
<detail>
<RequisitionFault xmlns="http://requisition.api.newscale.com">
<errorCode>AUTH_0005</errorCode>
<errorMessage>The user name header is invalid. It is either not present or empty!. Please send a valid header.</errorMessage>
</RequisitionFault>
</detail>
</soap:Fault>
</soap:Body>
</soap:Envelope>
Unfortunately, I cannot find any details on the meaning of this error or what its cause is. There appears to be a valud SOAP header. Is it talking about the HTTP header instead?
Thanks.
11-17-2011 05:39 PM
I posted this same question here on the form, bottom line this does not work. You need to pass in the username and password each time
