6 Replies 6
jwen2
Please be noted the commands related to “packet-forwarder” in this guide only work on Actility LRR, not other vendors’ packet-forwarder.
ivano.calabrese
Hi Jun Wen,
I'm working with the IXM-LPWA-800-16-K9 LoRa gateway, where:
The system version is:
Corsica Software, Version 2.0.11, RELEASE SOFTWARE
Copyright (c) 2012-2014, 2017 by Cisco Systems, Inc.
Compiled 18-Sep-2017.16:19:04UTC-07:00 by Corsica Team
ROM: Bootstrap program is Corsica boot loader
Firmware Version  : 2.0.11, RELEASE SOFTWARE
Bootloader Version: 20170515_cisco
cisco model: IXM-LPWA-800-16-K9
Processor  : ARMv7 Processor rev 1 (v7l) with 1027308K bytes of memory.
The FPGA versione is:
INFO: SPI speed set to 2000000 Hz
checking FPGA version...
FPGA version: 58
HAL version: 5.0.0
SX1301 #0 version: 103
SX1301 #0 chip ID: 1
SX1301 #1 version: 103
SX1301 #1 chip ID: 1
##PASS: FPGA version check OK
The packet forwarder version is
PublicKeyStatus : Installed
FirmwareStatus : Installed
PacketFwdVersion : 1.8.19
LRRID : 68ba4729
PartnerID : 0001
If I perform the following command (from configure terminal):
packet-forwarder start
or
packet-forwarder restart
I have a Radio issue.
17:46:21.404  (1825) [../lgw_x8.c:733] RADIO configured
17:46:21.404  (1825) [../lgw_x8.c:755] RADIO starting ...
17:46:21.404  (1825) [../lgw_x8.c:760] BOARD0 RADIO cannot be started ret=-1 'Invalid version number for the top FPGA'
So the packet forwarder doesn't start.
How could I solve this issue?
Regards.
jwen2
Please read the release notes of 2.0.11 for LRR support version.
ivano.calabrese
Hi Jun,
no I didn't.
I found this packet forwarder version on the cisco gateway. I didn't perform any kind of upgrade.
How could I upgrade the pktfwd to the lastest 2.2.46?
best regards.
pgrosset
Hi Ivano,
We would expect that you receive Thingpark LRR package through your standard channel.
If not, please, send me an e-mail, I will forward you a no-config LRR package.
Patrick
jwen2
Our software image never pre-install any LRR from manufacturing. No idea how you got this unit with LRR pre-installed, it is abnormal.
