返信
WS-C3850-48T-Sについて
yamashita.ry-03
WS-C3850-48T-Sについて質問致します。
購入時に以下IOSが入っておりました。
Switch#dir
Directory of flash:/
15490  -rwx     2097152  Aug 10 2015 17:10:30 +00:00  nvram_config
15491  -rwx    74369716  Jul 17 2015 22:38:50 +00:00  cat3k_caa-base.SPA.03.02.03.SE.pkg
15492  -rwx     5808828  Jul 17 2015 22:38:51 +00:00  cat3k_caa-drivers.SPA.03.02.03.SE.pkg
15493  -rwx    32496484  Jul 17 2015 22:38:50 +00:00  cat3k_caa-infra.SPA.03.02.03.SE.pkg
15494  -rwx    30418104  Jul 17 2015 22:38:50 +00:00  cat3k_caa-iosd-universalk9.SPA.150-1.EX3.pkg
15495  -rwx    16059104  Jul 17 2015 22:38:50 +00:00  cat3k_caa-platform.SPA.03.02.03.SE.pkg
15496  -rwx    64586444  Jul 17 2015 22:38:51 +00:00  cat3k_caa-wcm.SPA.10.0.120.0.pkg
15497  -rwx        1224  Jul 17 2015 22:39:01 +00:00  packages.conf
1621966848 bytes total (1393422336 bytes free)
Switch#
下記IOSに入替を実施したのですが
cat3k_caa-universalk9.SPA.03.03.05.SE.150-1.EZ5.bin
Switch#dir
15490  -rwx     2097152  Aug 10 2015 21:30:46 +00:00  nvram_config
15500  -rw-        1248  Aug 10 2015 18:10:47 +00:00  packages.conf
69697  drwx        4096  Aug 10 2015 18:11:14 +00:00  mnt
54212  -rw-    79122052  Aug 10 2015 18:10:42 +00:00  cat3k_caa-base.SPA.03.03.05SE.pkg
54213  -rw-     6521532  Aug 10 2015 18:10:42 +00:00  cat3k_caa-drivers.SPA.03.03.05SE.pkg
54214  -rw-    34530288  Aug 10 2015 18:10:42 +00:00  cat3k_caa-infra.SPA.03.03.05SE.pkg
54215  -rw-    34846028  Aug 10 2015 18:10:42 +00:00  cat3k_caa-iosd-universalk9.SPA.150-1.EZ5.pkg
54216  -rw-    25170832  Aug 10 2015 18:10:43 +00:00  cat3k_caa-platform.SPA.03.03.05SE.pkg
54217  -rw-    77456192  Aug 10 2015 18:10:43 +00:00  cat3k_caa-wcm.SPA.10.1.150.0.pkg
1621966848 bytes total (1313169408 bytes free)
Switch#dir flash:mnt
Directory of flash:/mnt/
77441  drwx        4096  Aug 10 2015 18:11:14 +00:00  images
Switch#dir flash:mnt/images
Directory of flash:mnt/images/
85185  drwx        4096  Aug 10 2015 18:11:15 +00:00  ap.bak
Switch#dir flash:mnt/images/ap.bak
Directory of flash:mnt/images/ap.bak/
85187  -r--          40  Oct 30 2014 20:24:04 +00:00  ap1g2.md5
85186  -r--    11612160  Oct 30 2014 20:24:04 +00:00  ap1g2
85189  -r--          40  Oct 30 2014 20:24:04 +00:00  ap3g1.md5
85188  -r--    10485760  Oct 30 2014 20:24:04 +00:00  ap3g1
85191  -r--          40  Oct 30 2014 20:24:04 +00:00  ap3g2.md5
85190  -r--    13783040  Oct 30 2014 20:24:04 +00:00  ap3g2
85193  -r--          40  Oct 30 2014 20:24:04 +00:00  c1140.md5
85192  -r--    10321920  Oct 30 2014 20:24:04 +00:00  c1140
85194  -r--          11  Oct 30 2014 20:24:04 +00:00  version.info
Switch#
パーミッションよりプライベートディレクトリだと思われますが
mntのディレクトリが作成されました。
削除しても動作に不具合はきたしませんでしょうか?
また、入替後、ファイルのパーミッションの有り方が違っておりますが
動作に不具合はきたしませんでしょうか?
ご教授いただきたく、よろしくお願い致します。
1 件の受理された解決策
受理された解決策
mousho1522
mnt/images/ap.bak 以下のファイルはバージョン変更時に作成されるAP 用のバックアップイメージなので、削除しても問題ないとおもいます。
パーミッションの方も、動作に問題はないとおもいます。
元の投稿で解決策を見る
2件の返信2
mousho1522
mousho1522様
ご回答ありがとうございました。
