Adding a User using AXL in CUCM
AR7
Frequent Visitor
Frequent Visitor
I am using AXL to add a User in the CUCM. I am using the following AXL syntax:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/9.1">
  <soapenv:Header/>
  <soapenv:Body>
    <ns:addUser sequence="?">
      <user>
        <firstName>John</firstName>
        <lastName>Doe</lastName>
        <userid>john.doe</userid>
        <password>1234</password>
        <mailid>[email protected]</mailid>
        <department>IT</department>
        <enableMobility>T</enableMobility>
        <phoneProfiles>
         <profileName>john.doe_EM</profileName>
        </phoneProfiles>
      <associatedDevices>
      <device>SEP001F3A924223</device>
      </associatedDevices>
        </user>
    </ns:addUser>
  </soapenv:Body>
</soapenv:Envelope>
The above works when I remove the tags for adding defaultProfile and primaryExtension. As a turn around i used the SQL statement for adding the defaultProfile but I am still not able to add the primaryExtension. is there an SQL statement for that?
dcburleigh
What error are you seing when you try to add the primary extension?
The WSDL contains this comment:
:Only DNs associated with the associatedDevices of the  User can be used as primary extension.
Is the DN/Partition you're trying to add already associated the device ?
