addUser problem.
alexandersatria_Zlf
Frequent Visitor
Frequent Visitor
Hello i got a problem when i tried a soap codes for addUser.
but  got this error
"Error sending/receiving from server: Server returned HTTP response code: 500 for URL: https://192.168.10.11:8443/axl/"
i use cucm 9.1
here's the codes
         HttpsURLConnection.setDefaultHostnameVerifier(allHostsValid);
         URL url = new URL("https://192.168.10.11:8443/axl/");
         //Create a java.net URLConnection object to make the HTTP request
         URLConnection conn = url.openConnection();
         //setDoOutput=true causes the URLConnection to perform a POST operation
         conn.setDoOutput(true);
         //HTTP Basic authorization string - a base64 encoded string with username:password, in this case 'Administrator:cisco!123'
         //This should be a UCM application user with Standard CCM Admin User and Standard AXL API Access roles
         String authorization = "operator" + ":" + "operator";
         authorization = new sun.misc.BASE64Encoder().encode(authorization.getBytes());
         conn.setRequestProperty("Authorization","Basic " + authorization);
         //Set the SOAPAction header to 'CUCM:DB ver=8.5' for use with a UCM 8.5(1) host, request is 'getPhone'
         conn.setRequestProperty("SOAPAction","CUCM:DB ver=9.1 ");
         //The request body will be in XML format
         conn.setRequestProperty("Content-Type","text/xml;charset=UTF-8");
         String AXLRequest = "<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:ns=\"http://www.cisco.com/AXL/API/9.1\">";
         AXLRequest += "<soapenv:Header/>";
         AXLRequest += "<soapenv:Body>";
         AXLRequest += "<ns:adduser sequence=\"?\">";
         AXLRequest += "<user>";
         AXLRequest += "<firstname>useer09</firstname>";
         AXLRequest += "<lastname>Sample</lastname>";
         AXLRequest += "<userid>jonesss</userid>";
         AXLRequest += "<password>1234</password>";
         AXLRequest += "<pin>1234</pin>";
         AXLRequest += "<mailid>[email protected]</mailid>";
         AXLRequest += "<department>Marketing</department>";
         AXLRequest += "<manager>Jane Doe</manager>";
         AXLRequest += "<associatedDevices>";
         AXLRequest += "<name>SEP000000000006</name>";
         AXLRequest += "</associateddevices>";
         AXLRequest += "<primaryextension>";
         AXLRequest += "<pattern>1010</pattern>";
         AXLRequest += "</primaryextension>";
         AXLRequest += "</user>";
         AXLRequest += "</ns:adduser>";
         AXLRequest += "</soapenv:Body>";
         AXLRequest += "</soapenv:Envelope>";
Try without specifying the <userRoles> elements - you should only specify the userGroup name, I think.
5 Replies 5
dstaudt
There are several places where the case of the XML elements is not quite right, e.g. 'adduser', 'associateddevices', 'lastname', 'firstname'.  Please ensure these are correct per the schema.  The below XML worked for me on a test system:
<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/9.1">
  <soapenv:Header/>
  <soapenv:Body>
    <ns:addUser sequence="?">
      <user>
        <firstName>useer09</firstName>
        <lastName>Sample</lastName>
        <pin>1234</pin>
        <associatedDevices>
        </associatedDevices>
        <primaryExtension>
        </primaryExtension>
      </user>
    </ns:addUser>
  </soapenv:Body>
</soapenv:Envelope>
Hello Mr. dstaudt
i already success try this codes
        <soapenv:Header/>
                 <soapenv:Body>
                     <user>
                       <firstName>Johhoney</firstName>
                       <lastName>Bishewoop</lastName>
                       <userid>qwey</userid>
                       <password>bishop</password>
                       <enableCti>true</enableCti>";
                      <enableMobility>true</enableMobility>
                       <imAndPresenceEnable>true</imAndPresenceEnable>
                        </user>
                         </ns:addUser>
                   </soapenv:Body>
</soapenv:Envelope>
but when i added "associatedGroup". it's showing error.
        <soapenv:Header/>
                 <soapenv:Body>
                     <user>
<associatedGroups>
           <userGroup>
              <name>Standard CCM End Users</name> <userRoles> <userRole>Standard CCM End Users</userRole></userRoles>
          </userGroup>
              <userGroup>
                 <name>Standard CTI Enabled</name>  <userRoles> <userRole>Standard CTI Enabled</userRole></userRoles>
             </userGroup>
             <userGroup>
                   <userRoles> <userRole>Standard CCMUSER Administration</userRole></userRoles>
              </userGroup>
           </associatedGroups>
                        </user>
                         </ns:addUser>
                   </soapenv:Body>
</soapenv:Envelope>
i tried this codes
<associatedGroups>
       <userGroup>
        <name>Standard CCM End Users</name>  <userRole>Standard CCM End Users</userRole>
      </userGroup>
        <userGroup>
                   <name>Standard CTI Enabled</name>  <userRole>Standard CTI Enabled</userRole>
              </userGroup>
                 <userGroup>
           <name>Standard CCMUSER Administration</name>  <userRole>Standard CCMUSER Administration</userRole>
               </userGroup>
             </associatedGroups>
but it's still error. can you help me how to fix it?
finally i got the correct codes
AXLRequest += "       <associatedGroups>";
  AXLRequest += "          <userGroup>";
  AXLRequest += "              <name>Standard CCM End Users</name>  <userRole>Standard CCM End Users</userRole>";
  AXLRequest += "          </userGroup>";
      AXLRequest += "                  <name>Standard CTI Enabled</name>  <userRole>Standard CTI Enabled</userRole>";
      AXLRequest += "        </associatedGroups>";
